Seeking knowledge of Nickel strike
Dear Sir/Ms.
I would like to get your advices about how to do " Nickel strike " on top of a nickel coated metal plate.
The purpose of the additional nickel layer ( nickel strike) is just to achieve better adhesiveness when the nickel striked metal is glued with another metal plate ( Zn coated)
Many thanks.
Wang ru hai
electronics mfg - Shanghai, China
Doing a nickel strike on top of old nickel plating is a workable process sometimes used on items like truck bumpers. In today's environmentally attuned times, it is sometimes deemed better to rectify some plating defects by adding a second layer than by stripping the original layer and having to deal with the waste from the stripping solution.
Personally, I've only heard of this being used as a workaround for defective parts in that way, not as a design strategy for new parts. For new parts, it's perhaps better to try to keep the nickel plating active rather than trying to re-activate it with a nickel strike.
A conventional Wood's Nickel Strike is suitable for the purpose of reactivating nickel plating.
I would try using some time of acid salt with current to reactivate the nickel.
Kevin Frankart
- Columbia City, Indiana
If glue is the next step on top of the original nickel, probably no chemicals are needed. A thorough dry or wet/dry scrubbing with pumice this on eBay or Amazon [affil links] or Scotch-brite might be all you need.
Guillermo Marrufo
Monterrey, NL, Mexico
