We're suffering from Rusty SS316L material
Why SS316L material pitted or show sign of rust on the surface of the material. We have done some non-directional hairline polishing on this material. Our product are use at area near to the seaside. Is there any way to remove this rust stain and is there any form of chemical we can apply on the surface to improve the corrosion resistance.
Maureen Ong
metal fabricator - Singapore
Hi Maureen,
Short, sweeet and succinct ... please go to the archives and hit # 19760.
freeman newton portrait
Freeman Newton [deceased]
316 ss is usually pretty good near the ocean, 304ss will not hold up. If you have rust on the surface you can get rid of it and repassivat the surface with some good citric acid formulations that are available in Singapore. There are a variety of products based on oxalic acid this on eBay or Amazon [affil links] that will remove the rust if you want faster action, then repassivate with the citric formulations to help it hole up better.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
To avoid rust or repair rusted 316-parts in seaside-applications, my experience is that electropolishing is giving the best results.
Marc Quaghebeur
- Brugge, Belgium
I agree with Marc, electropolishing gives the best results.
Klaas de Boer
- Heerenveen, the Netherlands
