What metal will corrode fast in acid
The time it takes for metal to corrode. I currently have to cunduct an experiment and I have a limited amount of time in which to conduct it so I was wondering which metal is the one that corrodes in acid the fastest so that I can finish my experiment in time.
Nicole M.
student - Brisbane, Queensland, Australia
Zinc will corrde very quickly in acid. So, after you have dissolved the zinc into the acid, what is the experiment you are planning to conduct?
