Multi plating of Kovar for soldering
One of our customers is requesting a change in plating to a Kovar strip which is soldered to a silicon solar cell. They have ask for Nickel strike 0.00003", then Copper plate to 0.00005 to 0.00015 thick, followed by a silver plate, type I, grade B to 0.00008 to 0.00012. Finally a solder plate 0.0002 to 0.0003 which is then fused. Does anyone have experience of this sequence of plating, with the advantages and dis-advantages?
Thanks in advance.
John Hughes
electronics - Hawthorne, California, USA
Advantages and disadvantages compared to what, John? You didn't say what you presently have experience in. I'm not a solder expert, but the step where you solder plate on top of the silver silver doesn't sound right to me, and all of the layers sound a bit thin.
