Electroplating equipment from Rapid Electroplating Process
Dear Sir/Mrs.,
We need your assistance about standard electroplating equipment manufactured by Rapid Electroplating Process Inc. This equipment is called out at T.O. 9H4-2-79-3 (Variable Delivery Hydraulic Pump Overhaul Instructions). We would like to have the Part Number and/or Stock number, price and delivery time of this equipment. I appreciate if you can respond and provide the information that we required.
Best Regards,
Hakan AYDINaircraft engine - ESKISEHIR, Turkey, TURKEY
I believe that this is brush plating equipment, and that companies offering it will be able to help you out.
Address for Rapid Electroplating Process is 708 West Soffel Avenue in Melrose Park Illinois 60160, which I believe is a suburb of Chicago.
Ray Wollenhaupt- Middletown, Ohio
Rapid Electroplating Process, Inc. is located at:
2901 W. Soffel Ave.
Melrose Park, IL 60160
We are manufacturers of portable plating equipment and supplies. The power unit is in a grey metal toolbox looking container. It operates from any 110-120 volt, 50-60 cycle A.C. It maxes out at 12 volts.
We are often confused with Rapid Power Technologies formerly known as Rapid Electric located in Brookfield, CT. They supply much larger rectifiers.
Rapid Electroplating Process - Melrose Park, Illinois, USA
