Removing scale from Stainless Steel
O.K. Guys,
I have a question. How do you remove heavy scale from 316 Stainless Steel without using Nitric Acid. I have used a proprietary mixture but to no avail.If anyone has a suggestion it would be most welcome. Thanks!
Christine Hardin- Hixson Tn
We have found that using a solution of hydrofluoric acid mixed 1;2 water removes scale and welding marks from stainless steel prior to electropolishing. If you need more information, please get back to me.
John Mattisson- South Africa
page 194 of the 1999 metal finishing book will tell you exactly how to get the scale off. sodium hydroxide sodium carbonate ⇦ this on eBay or Amazon] potassium permangamate almost boiling. it will work
todd huehn- coon rapids , Minnesota
