Nickel plating on extruded aluminum
Q. We are plating big volumes of cooler in extruded aluminum which have a design like a wide cam where the nickel doesn't get in fast enough so we solved AL in the zincate and in the nickel and create bad adhesion. we are today using double zincate with a little better results but not good enough. The part shall be plated with 10 microns of Ni and 10 microns of Tin.
Jan Malmquistplating shop - Huskvarna, Jönlöping, Sweden
? I am not familiar with this idea of going directly from zincating to electrolytic nickel plating, and not being so, I would have expected it to not work. Do you have a history of successfully employing it?
A. First use a dilute SINGLE zincate, rinse, dip in 4 oz/gal Sodium Bicarbonate, rinse, alkaline electroless nickel (which can stand 100 times as much zinc as acid EN), rinse, then final acid electroless nickel or sulfamate electrodeposited nickel, rinse then tin. ![]() Robert H Probert Robert H Probert Technical Services ![]() Garner, North Carolina ![]() 2004 A. Jan, ![]() Anders Sundman 4th Generation Surface Engineering Consultant - Arvika, Sweden 2004 |
A. Jan,
You don't tell us here if you use electroless nickel or electrolytic nickel before. If you use electroless nickel to plate at the first step I don't believe a alkali EN can helps you if this happens when the EN is new. An alkali EN is better than normal EN to stand more zinc and aluminium. Analyse if your problem's comes up after some MTO's if you use a normal EN solution or it happens with every MTO changes. Different electroless nickel solution from different suppliers have variations in the plating rate.
Anders Sundman
Sweden
A. You did not give any info as for the pre zincate process. Maybe you have a problem with the cleaner (etching or non etching?) What do you use for desmutting? Do you have fluorides in the desmut? All these parameters are highly important in this process.
Sara Michaeli
Tel-Aviv-Yafo, Israel
