Painting Surplus Zinc Plated Parts
Hello,
I have several surplus casters that are zinc plated and I want to paint them. I have used a cold galvanizing compound Cold Galvanizing Compound / Zinc Rich Paint in the past as a primer and then painted a color coat on top of it. I am unsure of the quality of the bond I get with this procedure. Is there a better way, or maybe a better primer or preparation procedure that will yield good results? Is there any way to remove the zinc coating entirely?
Thank you in advance.
Christopher Danninger
aviation related - Stoughton, Wisconsin
Ideally you should take the casters to a plating shop, who can easily strip and re-plate them.
muriatic acid this on eBay or Amazon [affil links] Muriatic acid will remove zinc plating instantly, but when used in a non-controlled environment, you risk personal injury, environmental damage, harm to surrounding items from fumes, and damage to the item you are stripping. I am not suggesting that you personally don't know how to use it, Mr. Danninger, but a lot of other people will read this.
your name here
