How to avoid barrel marks on plated parts
Q. In barrel acid zinc plating how to avoid barrel mark.
Senthil [surname deleted for privacy by Editor]
plating shop - Chennai, Tamilnadu, India
A. I am not confident what you mean by 'barrel mark', Senthil, but if you mean dark spots on the work that seem to echo the pattern of the perforations in the barrel, this is usually due to iron contamination. Please see the article "Improving your Chloride Zinc Plating Operation", by Stephen Schneider in our on-line library.
A. PRINT OF BARREL HOLES
1. C.D TOO HIGH
2. BARREL SPEED, i.e., r.p.m low
3. HIGH IRON CONCENTRATION
ajay raina
Ajay Raina
Ludhiana, Punjab, India
A. Iron in the plating bath is a problem we have addressed at our plant. But the latest is barrel overloading -- this will show the same spots due to parts not rolling in the barrel. Hope this helps.
Paul Ellingson
plating shop - Wahpeton, North Dakota
A. Barrel marks in acidic zinc are a result of divalent iron. You have to oxidize it with hydrogen peroxide or air. Then the solution will develop a brown sludge which is trivalent iron that has to be filtered. This procedure is a normal procedure which you have to perform approx. once per week. The divalent iron is produced in this solution all the time and you have to get rid of it.
sara michaeli
sara michaeli signature
Sara Michaeli
Tel-Aviv-Yafo, Israel
Q. Hello. I'm having problems with a piece. It's a small part like a domino; the thing is that the piece is taking the circles (or holes) from the barrel in the faces of the piece. What do I have to do to avoid this issue? Please: your help.
barrel mark on plated part
Cesar Garcia
- Saltillo Coahuila Mexico
August 22, 2013
