Removing scale buildup on stainless
I have a calcium silicate scale buildup on a machine made with a thin Stainless steel plate. Hard to access the scale, but can easily fill with liquid. Can I dissolve the scale and not damage the metal?
Billy Rice
MANUFACTURER - Belton, South Carolina, USA
To remove water scale build up in stainless steel heating or cooling jackets(Calcium Carbonate)a 10% by weight solution of Sulfamic Acid circulated at ambient temperature, should do the trick. You may have to replace spent solutions a few times through the processing as the reaction depletes. Rinse well!
Arthur Romo
- El Monte, California, USA
I think you can use ordinary vinegar in bulk on eBay or Amazon [affil links] .
citric acid formulations work very well for this, also.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
