Silicone sealant versus methanol
I have a problem about silicone sealants. Can I use a silicone sealant for the glass sight gauge on a tank? The tank will be filled with methanol [affil links](99.5%). So, will the methanol react with the silicone or contaminate the methanol? If not, how long will be silicone be capable to seal from leaking.
NAIMSAM AHMAD
engineer - KUALA LUMPUR, WILAYAH PERSEKUTUAN, MALAYSIA
It is highly likely that silicone reacts with methanol. I used silicone seals for my sample vials, with the sample dissolved in methanol. On analysis by LC (APCI)MS, I discovered extreme contamination. Mass spectra with a regular repeating pattern (polymeric nature) which I suspect to be as a result of silicone extracted by methanol.
I will greatly appreciate to hear feedback from others.
Samuel Mugo
Memorial University - St John's, NL, Canada
