Will 304 SS tank corrode from hot water?
Does SS 304 stainless steel tank corrode under hot water (hard water)?
ARUN PRAKASHmarketing - DELHI, DELHI, India
"Individual results may vary", but thousands of final hot water rinse tanks on plating lines are built of 304 SS.
No, up to hot water temperature i.e.250 deg.max. Super saturated steam.
- Pune, Maharashtra, India
no corrosion due to water on ss
Ashok bhatia- mumbai
yes,near welding seams because of chromium carbide formation during welding and following low chrome on grain boundary.you need higher chrome contained or heat treatment after welding. good luck
Khair Shishani
No corrosion on SS304. But you have to be careful about the welding part, where which welding material you have used for it. My suggestion is to use the welding rods of ss 316 or 310 quality for welding.
Pavan Jainstainless. - Mumbai
I have used 304 SS 10,000 gal tank at 204 degree F for 30 Years with only few problems at weld line.
Mak Gupta- Gilroy, California. USA
After welding/assembling you have to pickle and passivate and if thats not enough you may consider electropolishing.
K. de Boer- Heerenveen
We heard that Merloni is does passivation on the insides of their SS tanks. Corrosion and failures of SS tanks are quite common in India, wherever soft water is in use.
Murali RajagopalanWater Heaters - Tuticorin, TN, India
