How Does copper sulphate Test for Passivation Work?
Q. Dear Readers,
I have heard that a way to check for iron on the surface of a passivated stainless steel part is with the copper sulphate this on eBay or Amazon [affil links] test. From what I can gather the copper replaces the iron due to the fact that the iron is more easily oxidized. Chromium is more easily oxidized than iron, so why doesn't the copper also replace the chromium?
Thanks for your input.
Shaun C [surname deleted for privacy by Editor]
manufacturing w/ in-house plating - Sheridan, Indiana
A. Chromium and nickel will not be replaced with the copper sulphate test solution (which also contains sulfuric acid), only the Fe or other less noble metals. If there is free iron on the surface it will be replaced by the copper, forming the distinctive copper color on the surface in this 6 minute test.
Of course, this test should only be used on austenitic stainless steel. Some people use it on other grades, but you can get false failures.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
Q. Why is it that Fe is less noble than Chromium? From their locations it appears that Iron is more noble.
Chris L [surname deleted for privacy by Editor]
co-op/manufacturing engineering - Sharon, Massachusetts
A. Hi Chris. It's possible that you are misinterpreting the chart. Platinum and Gold are on the noble end of the seawater series, magnesium is on the active end. Nickel and chromium are closer to platinum than steel is.
Q. I need to determine effectiveness (pass/fail) of an up-coming passivation procedure. I have read that using copper sulphate is a proper method, however, I have not found a test kit, only the copper sulphate itself. How do I go about constructing a procedure or test method?
John Stiglbauer
- Columbia, South Carolina
April 16, 2008
A. To answer John's question, I'd look up a standard test and use that, rather than make my own. Primarily because I'm lazy, but you can also argue that something published by a known organization probably has had some thought behind it, maybe it's been vetted as well.
So I'd go to Assist Quicksearch by typing that into Google and hitting "I'm feeling lucky". Then I'd type "753" into the number box, and click on the icon that will display MIL-STD-753 [⇦ this spec on DLA / cancelled] revision C [replaced by AMSSTD753]. Then I'd read that one, and if it met my needs, I'd use it.
lee gearhart
Lee Gearhart
May 4, 2008
Q. Once or twice a year my company use copper sulphate to check for surface free iron on 300 series stainless steel.
The copper sulphate is in powder (crystal) form that is made into a solution.
We misplaced the instructions on how to make the solution.
What is the proper way to test for surface free iron and how is the solution made?
Bob Hildebrand
material fabricator - West Islip, New York
April 2, 2009
A. If you need instructions / information look up ASTM A380 section7.2.5.3 copper sulphate test.
A company that makes and sells kits for this is Koslow Scientific Company in Englewood, New Jersey.
Francisco Robles
- Denver, Colorado USA
June 23, 2009
A. copper sulphate solution is a saturated solution. It should be kept fresh.
Be sure to carefully remove all of the copper deposits. This is a slightly destructive process.
Koslow Scientific company sells a color spot test kit that does not require any mixing of chemicals. It is called the Passivation Color Kit 1626. The color reaction takes place not on the metal surface but on a sensitive test paper.
Gary Huller
koslow banner
July 24, 2012
Q. What is the aim of the copper sulphate test in martensitic stainless steel used in dental hand instruments? What is it testing?
Dr.Hany Elwahsh
Acrostone - Cairo, Egypt
June 7, 2015
Q. Is it a requirement to be an A2LA certified to perform a passivation test for Stainless Steel?
Randy Phillips
- Richfield, Wisconsin, USA
January 11, 2016
thumbs up sign Hi Randy. It's an interesting question, but I'm not sure that it's worded quite clearly enough.
I should think that anyone who can safely perform a passivation test is welcome to perform one, but that we can't put much credence in their results if we don't have reason to trust their qualifications :-)
Can we have the situation? Thanks!
January 2016
A. Randy,
The question is, is it a requirement by whom? The ASTM and SAE standards on passivation don't say anything about certification. If your customer asks for A2LA though, then you need to have it.
ray kremer
Ray Kremer
McHenry, Illinois
January 11, 2016
Remove copper deposit after stainless passivation testing
Q. After performing the copper sulphate test, which might be the best way to get rid of the copper deposits on the SS surface.
angel_espinosa
Angel Espinosa
electronics - Swindon UK
September 12, 2016
A. Good day Angel.
If you are passivating in the nitric based solutions, give the parts a dip in the passivating solution. Keep this solution off line for this purpose only, to avoid contaminating the process solution with copper.
Eric Bogner, Lab. Tech
Aerotek Mfg. Ltd. - Whitby, Ontario, Canada
September 12, 2016
A. Angel
Your question implies that the test parts failed. Dial in your passivation process and you won't have deposited copper to remove.
Willie Alexander
September 12, 2016
Q. Hi Eric,
Thanks for the reply. I am planning to perform the test during maintenance activities after cleaning the plates. Is there a way to remove the copper deposits without dipping? Thanks again. Angel
angel_espinosa
Angel Espinosa [returning]
September 13, 2016
A. Angel,
Sodium persulphate with a little bit of acid in it makes a good copper stripper that isn't very hazardous to work with.
ray kremer
Ray Kremer
McHenry, Illinois
September 13, 2016
Q. I have some parts (stainless steel) that they have already been chrome plated or electropolished. My question is, after passivation, do I have to perform the copper sulphate test on those parts which already been chrome plated?
John Zhou
Medical Device Manufacturer - West Hills, California, USA
November 8, 2017
A. We've talked already about this, but I will answer here also for the benefit of other readers.
First I will note that chrome plating and electropolishing are very different things.
Chrome plating is not normally done with stainless, and if it is, I see no reason to passivate or run a passivation test because the stainless has been covered over. copper sulphate is often used to check for gaps in plating over carbon steel though.
Electropolished stainless can be citric passivated for extra good corrosion resistance, at which point it's certainly fine to run copper sulphate testing in order to comply with the relevant standards. If you don't have to comply with the standards, then it's pretty much up to you.
ray kremer
Ray Kremer
McHenry, Illinois
November 10, 2017
Q. Hello all, I would like to know what's the actual chemical reaction in the copper sulphate test, specifically what's the reason of having sulfuric acid in the reaction?
I've realized that the copper sulphate solution that we are using meets the ASTM F1089 standard in terms of copper sulphate pentahydrate %, however the mass weight % for sulfuric acid is slightly different (F1089: 0.7%, Solution: 0.6%) and would like to know if such an small difference could have an adverse effect on the process.
Juan Carlos Brizuela Marin
Manufacturing of medical devices - San Jose, Costa Rica
December 11, 2018
Q. I am wondering what the industry standard is for the use of parts after being tested with the copper sulphate solution. Can the parts still be used after testing? There is a question of whether the residual copper sulphate has a negative effect on the tested parts. Our parts are mainly used in the medical industry, semi invasive and implantable medical devices.
Eric Hennen
medical - Brooklyn Park
January 23, 2019
A. Juan,
The copper sulphate test as far as I know originated in MIL-STD-753 [⇦ this spec on DLA / cancelled], and probably will still work fine if the amounts are slightly off, though you would still be "out of spec" for using it.
A. Eric,
Copper is fairly toxic to living cells. In theory, a stainless part passing the copper sulphate test will have no residual copper and will be safe for medical use. However, the attitude in the industry is that nobody wants to undertake the task of proving this is a reliable certainty, therefore ASTM F1089 requires that any medical instrument tested with copper sulphate be disposed of. Personally I think there ought to be other practical ways around this, but if you need to be compliant to F1089 that is the rule.
ray kremer
Ray Kremer
McHenry, Illinois
January 29, 2019
adv.    koslow passivation test kit
