Galvanizing vs. plating for racking components
We are in the manufacture of racking components made out of HR steel of 1.6 & 1.8mm thickness. We average life span is 15-20 years. I would like to know out of electro plating and hot dip galvanising which will be a better option for this. At times these are used in cold storage applications also where the temperature can be as low as minus 30 °C.
UNNIKRISHNAN N NENGINEERING - SHARJAH, UNITED ARAB EMIRATES
HOT DIP IS A LOT BETTER. FIRST, THE ZINC IS THICKER AND IT IS DIFFUSED INTO STEEL SO THE ADHESION IS BETTER -- BUT IT MAY BE MORE EXPENSIVE MONEY WISE.
Khair Shishani
DEAR MR UNNI
GALVANIZING IS A PROCESS IN WHICH LAW OF give and take applies so how much you give that much you can take. So the thickness of zinc in hotdip is more so you will be much more safe and specially in this part of world where climate is humid. So you get your puzzle solved. Regards,
- Ajman, UAE
Hot dip galvanizing will give you long lasting protection for your steel.
Syed Kazmi- Dubai
