Need to do SEM of silver plating microstructure
Dear sir
I want to see microstructure of silver plating on copper by SEM , But nothing shows it. I did etch by H2O2 Please tell me how do it?
Hashemi
Malek-Ashtar Tech. Univ. - Shahinshahr, Esfahan, Iran
For etching silver use a mixture of cyanide and persulphate (mix 5% Potassium cyanide solution and 5% Ammonium persulphate solution 1:1 ) or a potassium-chromate solution (100 ml saturated potassium chromate -solution + 2 ml saturated sodium chloride -solution + 900 ml of Water). Be careful as both cyanide and chromate are poisonous. Polish the silver before etching and try first to use an optical microscope, I think to use a SEM is not necessary.
Good luck,
Marcus Hahn
- Lucerne, Switzerland
Dear Mr. Hahn,
I need SEM to compare between deposit from cyanide solution & Iodide solution.
Hashemi
- Iran
