Flash rusting problem when stripping chrome
At present we remove hard chrome from large 20 ton + castings with a sulfamic acid ⇦ this on eBay or Amazon [affil links] salt solution(not possible to use sodium hydroxide electrolytically) after rinsing the castings we immediately get flash rusting, we have tried rinsing in a sodium hydroxide solution immediately after the sulphamic acid solution (limited success) does anyone have any ideas on how to prevent the rusting ?
Norman EvansPlating - Springfield, Ohio, U.S.A.
Norman
Try this.
1) Raise component.
2) Slip a tray underneath which will carry away copious quantitys of dripping solution while transferring the component...
3) - IMM shift manually via overhead crane to a continuously flowing rinse bath. Immerse in RINSE bath.. Run air agitation vigorously.. The rinse shld be just large enough, not oversized. This is a key point..
4) Run water thru Rinse bath. Do not remove component. -Watch the ph. once it crosses 5 and rises towards 6... and hits 7 ....
5) Introduce a 7 to 10 % concentrated solution of caustic soda ⇦liquid caustic soda in bulk on
into the rinse. A wetter at 0.1 % helps...
The air agitation can be stepped up to scrub the component till all the surfaces are totally neutralised. Maintain the pH around 8-10 . Thereafter remove and allow to drip into Rinse .
Air dry.
There is an obvious element of skill involved here. Try this with a small set of beakers [beakers on
Amazon [affil links] s first on a table top to get the idea into work sequencing.
Good Luck.. Regards,
Asif Nurie [deceased]
- New Delhi, India
