Stripping Tin Plating from Silver
Q. Information for Tin strip from Silver plating.
Louis Hirboursupplier - Anaheim , California, USA
A. You could try caustic soda ⇦liquid caustic soda in bulk on Amazon [affil link] solution as the solvent and sodium chlorite solution as the oxidant. Am not sure of the effect on silver so keep an eye on it. ![]() Geoffrey Whitelaw - Port Melbourne, Australia 2004 2004 A. Try 1-HCl OR 2-NaOH 100 G/L +NaCO3 20 G/L --ROOM TEMP GOOD LUCK ![]() Khair Shishani aircraft maintenance - Al Ain, UAE |
Q. I am an engineer in the plating industry. Currently I am working on a project that requires silver plating as the final finish for electrical contacts. The customer wants selective tin plating on certain parts of the contacts and I need a tin backstrip that will strip flash tin from bleed out but not discolor or strip the silver. Any help would be greatly appreciated.
Kate
- Hudson, Massachusetts, USA
July 10, 2014
A. Hi Kate,
You may try MSA base immersion type tin stripper which shall not attack silver.
David
David Shiu
