Nitric Strike Tank Test Question
Q. I work for a metal finishing shop and have a little problem. Our pH meter has had a heart attack. I am now in a process of turning my tank titration testing procedures from using the pH meter to using indicators. I have done a pretty good job until I ran into the testing of our Nitric Strike tank; tank containing ~45-50% nitric acid concentration. I have tried consulting our books and have not been able to find a titration method that utilizes an indicating solution that has the appropriate visual transition. Should I use Thymol Blue, an indicator with visual transition of 1.2 - 2.8 from red to yellow? If you have any ideas, I am more than willing to listen to them.
Noel Yang
plating shop - Oldsmar, Florida, USA
A. That will work, but one that changed color around a pH of 4 would be a more normal choice. Experiment with methyl orange this on eBay or Amazon [affil links] and with methyl red this on eBay & Amazon [affil links] . Cheap and functional. I preferred 0.5 N sodium hydroxide this on eBay or Amazon [affil links] over 1.0N because it is weaker and does not tend to precipitate out any metals because of a locally high pH. A mixer with a teflon spin bar works a lot easier than swirling with an erlenmeyer Flask. It is worth the extra few bucks in the long run.
