Tin precipitation problem
Q. How can I precipitate tin from acid solution?
Luis Humberto Leal MontoyaRecycling field - Tijuana, Baja California, Mexico
A. Although your question is vague and generic, almost all heavy metals precipitate if the pH is raised to somewhat alkaline (a pH of, say, 9 to 11). Naturally there may be many possible interferences and solubility levels to contend with, the possible need for coagulants, co-precipitants, long chain polymers.
If you want to remove the tin while retaining the acidity, perhaps you can electroplate the tin out of solution.
Q. Tin was dissolved with HCL, how can I precipitate it.
Luis Humberto Leal Montoya- Tijuana, Baja California, Mexico
