Chemical polish finish on stainless tubing
Q. Is there a chemical process to bring #4 stainless finish to a high polish, we are now doing it by hand rubbing.
Joseph BelliMfgr - Montreal, Quebec, Canada
A. Are you talking about internal surface polishing? if yes what is the max length, min diameter? There are two ways to polish internal surface: Electropolishing without pumping the electrolyte for pipes with diameter larger than 80 mm;
Electropolishing by pumping the electrolyte -for pipes with diameter from 14 to 80 mm. Both methods are based on acid-free electrolyte in which foam formation during the process do not prevent from electropolishing.
Anna Berkovich
Russamer Lab
Pittsburgh, Pennsylvania
