Passivation process for medical grade Stainless Steel tubing
Q. We are manufacturers of Medical electronic devices which uses SS 316L tubing as a fluid pathway which could be any IV fluid. I want to know the best passivation process for such tubing which will ensure corrosion free tubing surface for the fluids in contact. What is the duration that we can safely keep to ensure that the tubing inner surface is still valid for use. The devices are single patient use and when packed and sterilized, the expiry date is to be put on the device.
SomashekarElectronics Manufacturer - Bangalore, Karnataka, India
A. A device made of 316L should not need to be passivated to deal with IV fluids, especially a single patent device meant for short term use. There can be other factors involved, but as long as your tubing is dirt/rust free when it is packaged, you should have no problems. Since you are a manufacturer, I am guessing that the designers specified passivation? If it were an implant, reusable, or meant for long term use (>24 hrs or so), then I would passivate. But that doesn't seem to be your case.
Nitric acid, citric acid and electropolishing are all perfectly acceptable methods of passivation for medical devices. I can track down specs for you if you still need them. Citric tends to be far and away the easiest to deal with in terms of nasty chemicals and processing. The spec on that is ASTM A967.
Marty Padget- Santa Clarita, California, USA
A. Most medical devices require passivation, even for single use, because of the potential for iron contamination in the manufacture of the device and the corrosiveness of blood. I agree that 316L stainless should not require passivation for short term IF it is iron free to begin with. citric acid formulations are used for this kind of operation and are available on the market. Once passivated the surface has a very long life. Let us know if we can help.
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
A. Yes, if at the time of manufacturing if any kind of iron contaminations are there in SS 316L surface part then it can cause corrosion. So, best method to prevent such problem is to use Biodegradable, Chelant passivation for SS surface which is also used by many Ltd. Pharmaceutical / IV manufacturer companies in India. So, you can very safely use the same for your requirements also. That will prevent rusting / corrosion of your SS clinical part.
Vinay Golwala- Mumbai, Bombay, India
