Corten steel for flues in concrete chimneys
Q. I design industrial structures and that includes concrete chimneys with steel flues. Some years ago, I ran across some drawings for chimney flues which specified chimney flues made of corten steel.
Corten steel is not normally sold in India. I want to know whether anyone can advise me on the benefits of using Corten steel in a chimney flue instead of mild steel (excluding the top) since corten steel requires to be imported into India.
Solomon Lamech
structural engineer - Chennai, Tamil Nadu, India
A. COR-TEN® is a registered trademark of United States Steel Corporation. Their website www.ussconstruction.com has the info you need.
Karl Munson
- Cuncinnati Ohio USA
A. COR-TEN® is a type of weathering steel produced by US Steel that uses alloying elements such as copper, chromium, silicon and nickel to enhance the atmospheric corrosion resistance of the steel. The addition of these elements also results in a high strength steel that typically exhibits a 50 ksi minimum yield strength. ASTM A606 Type 4 is usually specified for this product. You can find additional details on their website.
Toby Padfield
Automotive module supplier - Michigan
Q. I am aware that "Corten" steel was extensively used on Gas turbine exhausts due to its high temperature and good servicability. Can someone supply me with material details/composition/purposes/etc. info. Is it still "milled" these days? are there improved equivalents?
Helmut Laszig
- Cape Town
Q. Can I use corten steel without paint for vent stack chimney, where temperature will be 400 °C? The temperature may fluctuate randomly from 30 °C to 400 °C.
Manzur Zahed
fertilizer manufacturer - Chittagong, Bangladesh
April 1, 2013
