Porcelain enamel surface prep
Q. After exposure to direct fire vitreous enamel coating is getting peeled off from my product. Is there any alternative for this coating?
Karthikeyan Ekambaram- Tamilnadu Chennai India
November 27, 2021
by PEI Technical Forum
A. Hi Karthikeyan. If you are using true vitreous enamel (powdered glass), it's hard to think of anything better. If it is peeling I'd investigate a better cleaning process rather than a better coating process. The enameling won't stick properly to a substrate which isn't spotlessly clean.
But what is the substrate?
November 2021
Q. I'm looking for information on how to prepare steel for porcelain enameling. All I can find mention of is that a "pickling" solution is used. If someone can identify the specific acid used and a source for it, I'd appreciate it. If you know of a reference book on this process, I'd appreciate being told the title & publisher, etc., too.
Elizabeth O'Connorglass works - Spartanburg, South Carolina
A. A pickle for steel could be as simple as 10% muriatic acid ⇦ this on eBay or Amazon [affil links] , but I don't know for sure about enameling. Here is a book at amazon.com, of which finishing.com, inc. is an associate: (This book got a good review over at amazon, and it is around 8 bucks). Metalwork and Enameling by Herbert Maryon, Paperback - 335 pages 5th edition (January 1984)
Good luck, tom
Q. I AM HAVING PROBLEMS OF COPPERHEADING IN THE GROUND COAT OF PORCELAIN VITREOUS ENAMELING OF STEEL PRODUCTS. I SHALL BE GRATEFUL IF ANYONE COULD PLEASE ADVISE ME ON WHY THEY OCCUR AND HOW TO GET RID OF THEM. ANY REFERENCE TO ANY TROUBLESHOOTING BOOKS WOULD ALSO BE WELCOME.
THANKS
BAKHSHI
TEJBIR BAKHSHIKOTA,RAJASTHAN, India
A. A good clean part is all that's required for enameling. A customer in Florence uses a six stage spray wash for cleaning the parts, with a simple alkaline cleaner. They get good results as long as they keep the concentration up and pay attention to the process. Cleanliness is absolutely critical to enameling, so don't skimp on it. But no other treatment is needed.
Jeff Watson
- Pearland, Texas
by Andrew I. Andrews
Q. WE are interested to know corrosion & wear resistance characteristic of PORCELAIN ENAMEL coatings. We are interested to start ENAMELING work at BARODA. WE need know the application method for the same. Can you help us ?
ASHOK SAHASRABUDHETHERMAL SPRAY job SHOP - BARODA, GUJRAT , INDIA
