Coatings for titanium fasteners in salt water
Does anyone have suggestions for coatings for titanium fasteners? The titanium needs to be coated because it is in contact with a dissimilar metal (aluminum) and will be submerged in salt water.
Sam C [last name deleted for privacy by Editor]- Manassas, Virginia, USA
YOU CAN ANODIZE TITANIUM IN H2SO4 , AS ALUMINIUM, AND IF YOU LIKE YOU CAN NICKEL STRIKE AND GO FOR ANY PLATING YOU WANT, REF BOOK , AND TRIED. P.S. ANODIZE FOR APPROX. 5 MINUTES , AROUND 1.5 AMP/SQ.DM.
Khair Shishani
Anodizing Titanium in an alkaline bath to the AMS 2488 should be a better option than color anodizing Titanium in sulfuric acid bath, as the color anodizing does not have a lot of physical properties that would discolor when handled with bare hands.
The alkaline anodizing process would form a Titanium oxide film that penetrates the base metal at a thickness range of 0.0002 - 0.001", It also hardens the metal surface for abrasion resistance. In addition, there is a proprietary additive that makes the coating lubricative for heavy loads wear. In combination with a Teflon impregnated process, the coating would increase the wear life of the anodize and for salt water application, be a barrier coating that would serve as an added protection from halogen/chloride attack on titanium. The Teflon would also serve as a release compound that would prevent Algae, barnacles or other undesirable sea creatures from adhering to the hardware.
B. Milla- Huntington Beach, California
