Lacquer coating our line of stainless garden furniture
Can I coat lacquer on the stainless steel surface for garden furniture? Would it help to protect from dirt and rust contamination?
Bupphagarden furniture - Prapradaeng, Samutprakarn, Thailand
Hello,
The best coating systems for stainless steel furniture would be urethane or polyester, both are available in powder and wet paints.
Jake KochG. J. Nikolas &Co.,Inc.
Bellwood, Illinois
Hi,
I am informed by our clients who coat stainless steel that it is one of the most difficult substrates to obtain adhesion - the coating film results in a envelope without good adhesion
- they use our waterbourne primer sold in the UK to overcome this problem.
To check adhesion cross hatch a section of your coated work apply some masking tape and pull this off quickly - none removal of the coating = good adhesion - try again on the same item after 3, 6 & 12 months outside exposure.
Terry HicklingBirmingham, United Kingdom
