Alternative to anodizing aluminum black
Hello,
I am a university engineering student looking to design a temperature controlled hot plate as part of a project. I have a very limited budget and have found that anodizing aluminum is somewhat expensive at our school shop.
I am looking for a material that conducts heat well, can be machined (to make a well to hold resistors and wiring along the bottom of the plate) and is preferably black (to reduce glare because there will be images taken of the material above the hot plate). Can anyone please offer any suggestions?
Mike Rosa
student - Waterloo, Ontario, Canada
Good finishes do not come much cheaper than anodize. If you do not have a wear problem, you might be able to use aluminum and paint it with a high temp flat black paint. The paint will last better if you chem film it first (Alodine, Iridite and etc). You must let it dry for 24 hours after chem-film before painting.
You can colour aluminum black chemically (without anodizing):
10 grams ammonium molybdate
5 grams sodium thiosulphate this on eBay or Amazon [affil links]
1 lit water
Hot immersion(100 °C)
