  Thread 296/72
Technology for plastic coating on Metal - Mild steel
Q. We are leading manufacturers of steel furniture for Educational Institutions and Hospitals. We have our own powder coating unit. Now we want to coat steel furniture with plastic. We do not know the technology. Hence this request. I request you to help me in this regard.
Thanking you,
Shambu Basavanal
Mfrs: Steel Furniture - DAVANGERE, KARNATAKA, INDI
publicly reply to Shambu Basavanal
A. Dear Shambu,
I am curious as to why you would want to change from a thermosetting powder to a thermoplastic powder for steel furniture. I can see no advantage for this. If you are having problems with steel defects I would suggest moving to a textured thermosetting powder coating.
Drew Devlin
- Lincolnshire
publicly reply to Drew Devlin
A. As the previous respondent said, that seems a strange move towards thermoplastics. Maybe you want thicker coatings? Similar application equipment can be used to spray thermoplastic powders, but the steel needs preheating before spraying. If your plant is configured this way it might be possible to do it with the plant you have now. Speak to powder suppliers.
geoff_crowley
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
crithwood logo
publicly reply to Geoff Crowley
A. Hi,
One reason to change to a thermoplastic (Nylon) when coating hospital furniture would be it's anti bacterial properties although there are (covered by worldwide patents) anti bacterial polyester powders now available.
Terry Hickling
Birmingham, United Kingdom
publicly reply to Terry Hickling
29672-0
We manufacture welded steel tube furniture and want to plastic coat our new outdoor dining range. Please advise on what technology is the simplest and would give very thick matte/gloss finish. You can check out the kind of finish we want.
IKPEME Ikpeme
- Calabar, Nigeria
November 19, 2011
publicly reply to IKPEME Ikpeme
June 11, 2012
Q. Dear Sir,
We have to plastic coat the SS trays for tool handling. Please give the plastic coating type which will withstand up to 150° and is also chemically resistive.
29672-1  29672-2  29672-3
Thanks and Regards.
Dattatraya Dixit
- Jamshedpur, Jharkhand, India
publicly reply to Dattatraya Dixit
A. Nylon coating on basket is advised to perform at the asked temperature and also chemical resistance up to normal solution strength.
dilip deshmukh
coatings - Pune, Maharashtra, India
July 28, 2012
publicly reply to dilip deshmukh
