Tin Solder coating for mil 202 method 208
Hi,
I have brass parts to quote on in work and one part specifies a "Solder coating 300 to 500 microinches" that must pass a solderability test per mil-std-202, method 208. The other part calls for a Tin Solder Coating 0.0078 to 0.0127mm. I have no idea what this finish is, I know it is used in the electronics industry but we are mostly involved in the semi conductor and medical industries.
John Hayes
Engineering component mfgr. - Dublin, Ireland
The solder coating you may be looking for should be covered under MIL-T-10727 (ASTM B545) or AMSP81728.
Gregory Smith
- Newtown, Pennsylvania, USA
