Buffing aluminum triple trees for my Harley
I have achieved a mirror finish on aluminum, but still seem to leave cloth swirls from cotton rags on the final cleaning. Can you suggest a type of material for the final stage.
Paul Racinehobbyist - Reno, Nevada, U.S.A.
The swirls are probably made by left over buffing compound that is on the aluminums surface being rubbed across the aluminum by the cloth. I would suggest after final buffing steam cleaner ⇦ this on eBay or Amazon [affil links] the part or use a low-mid speed dry(unloaded with compound) buffing wheel and go over the part with light pressure to remove any grit that is stuck on the surface.
Jason Aube- Flint, Michigan
