Computer Metals Scrapping & Recycling
     Computers and scrapped electronics have precious metals like gold and platinum plated on some of their components.
     Unfortunately, the gold plating, especially on newer components, is ludicrously thin and quite difficult to recover.
     The platinum on disc drives is even harder to recover. Read on ...
Q. I am a disabled person and my pay is very low I am trying to find a way to subsidize my income, so I can live. I have found that there are millions of Old obsolete computers out there that people are more than glad to get rid of. I just need to know the how-to and what-of recycling these computers. What parts do you take from them. How do you retrieve the metals. Any and all information would be greatly appreciated. Two people living off of $800 a month is extremely difficult, With Dr. bills, Meds and ..... Thank you very much for your help.
Marvin J [surname deleted for privacy by Editor]
Electronics - Newalla, Oklahoma, U.S.A.
A. Sorry for your hardships, Marvin, but they don't mean that recycling this stuff will prove feasible just because you'd like it to be. Read on or see thread 18889 for some data. But good luck with it!
RECOMMENDED BOOKS ON GOLD RECOVERY
refining_clark2014
"Gold Refining" by Donald Clark (2014)
refining_gee
"Recovering Precious Metals" by George E. Gee (2002)
refining_ammen
"Recovery And Refining Of Precious Metals" by C.W. Ammen (1984)
refining_hoke
"Refining Precious Metal Wastes" by C. M. Hoke (1982)
refining_gajda
"Gold Refining" by George Gajda (1977)
A. Well, where do I start...... As far as the knowledge I hold on recycling computers goes...... Monitors, printers, and scanners are supposedly worthless. You basically have to pay people to take them. The tower itself is a different story. First you have the steel frame around it which is basically worth a penny a pound to any scrap dealer. There is also the steel cover, but sometimes it is plated with PVC vinyl which may be able to be recycled for about two cents per pound, and the plastics facilities probably want the material to be clean, and not stickered up. Past the frame there are wires, boards, drives, and hopefully a few chips (every computer has different components in it - some with added hard drives and some with no drives..... really depends on what the previous owner did with the confounded thing anyway before it wound up in some trash pile and into your hands.
The insulated copper wire in the computer averages about 7/10 of a pound. Relative scrap price is probably about 15-25 cents per pound.
The disk drives and cd drives are somewhat worthless, however there are a few that are built on a cast aluminum frame. Removal of all parts can be quite tedious, and some of the parts may not come out of the casting without some form of industrial destruction. Average price of cast is about thirty cents per pound. One may get a little more if they separate the clean cast from the dirty cast (dirty having other metals/plastics/contaminants/etc......... The older cd drives may also have a cast aluminum base, but have a few hunks of copper behind a steel plated magnetic disk(a precision screwdriver set would probably be helpful if an attempt at the diamonds in the rough is going to be made).
Not sure of an average weight on the bare copper wire, but average scrap prices are ninety cents for dirty and a dollar for clean.
Torx Screwsdrivers
torx
The hard drive is probably going to be the most valuable drive in the computer, provided you are lucky enough to get one. All of the hard drives that I have seen are aluminum and most require torx keys to open them
T-10 Torx is the largest size that I have had to use, and T-9 is the most common, but a T-8 is definitely needed if there is an attempt to consistently recover the nickel coated aluminum disks. Unfortunately I am not too sure what the recovery value is on a pile of those disks because nobody can give me a straight answer. I was told however that they should be able to go in the old sheet category at almost any scrapyard. Price on these disks is probably about twenty five to thirty cents per pound. A T-7 key may also be needed, but I am not too sure on that one. There is also all the crap from the reader and a lot of aluminum spaced between the disks. That aluminum is in the category of clip, and has about a five to fifteen cent greater value than old sheet. The motor?...there is a little flying saucer shaped disk at the bottom of the hard drive after all the disks are removed. Not sure what all the components of that are maybe aluminum, stainless, and steel?.. Anyways that is an item that is considered Irony Aluminum, also known as breakage, and goes for about seven to ten cents per pound.
The boards are supposedly where all the money is..... right? Usually there is a motherboard, network drive cards, sound cards, and other various cards. On most motherboards there will be a heatsink with a cpu chip below it. Once removed from the board a hammer and screwdriver will usually chisel the aluminum heat sink off. The heatsink is another item that can go in the clip category.
The cpu chip is what is supposedly so valuable, but I'll get back to that one in just a moment. Also on the motherboard there should be a battery, memory cards, some ic chips (black plastic chips that are removable....pry off with a flathead, and caution because the prongs are very sharp), and if one really wants to be a shrewd miser there are sometimes small aluminum heatsinks by torroid inductors(the little circular things with copper windings all around) grab those and the copper wound inductors. Beneath the copper windings is ferrite. Not sure what the value on that is but they can go as a copper recovery item at the yards - about ten to fifteen cents per pound. Haven't really messed with the male female connectors that are to have all the gold plated pins. Also there are probably some cylindrical looking objects with a silvery top covered with plastic. I believe those are tantalum capacitors. I don't really mess around with those either. After removal of the simple objects the boards can go to select scrapyards for ten to fifty cents per pound. The network and drive cards are usually the main supplier of gold fingers and sometimes have IC chips on them too.
Now to the worst part of this whole "science experiment" is the little metal box with all the wires coming out of it. Have been told that they are worthless, so clip the wires and try to get a penny a pound out of the things (there is a copper wound torroid inductor inside the box, but since it says don't open the box due to possible live electrical current in a dead box or whatever and I have opened a couple of boxes.....my best description is that it is the dirtiest and ugliest mess in the computer so my best advice is don't waste your time). Some places may not want to mess around with the boxes or the disk drives so calling around first may be the best route for these items.
Now to the best part of course are the cpu/sim chips and ic chips. There are a couple of styles of sim chips. The best are the flat backed grey pentiums with the gold pins and square on the back. Aside from the gold the chip itself is 76% Tungsten, a semi-precious metal worth between two to four dollars average at some scrapyards. (Removal of these pins would probably be best suited for recovery of tungsten at a yard. eBay seems to be a good place to sell these chips). The other chips are believed to be ceramic - they all seem to have an aluminum plate stuck to the top and a grid in the center of the square of the gold pins - the cyrix chips are I believe silicone with gold pins -Pentium II are junk - Pentium III are plastic with gold pins. There are only about three different kinds of removable ic chips that I have seen. Out of the three there are some that are in a little square on boards which can be removed with precision tools, they and other light chips are silicone chips, not sure what the metal tips are, but copper and silver can be found in these chips (very hard to get to with a hammer...........trust me.........and what a mess). The other IC chips, believed to be high grade, have a metallic body usually with a holographic sticker covering a glass window.....below the window is quite the rare looking metal and very tiny too....I believe that it is platinum (even harder to get to due to the metal once again being 76% tungsten).
"Hand-Held X-Ray Analyzer"
(scrap sorting & alloy identification)
x_ray_alloy
And finally to the hardest part of this experiment the time and effort to research all the metals, organize the various categories to accumulate the material, know where to cash what in at, and have enough space to store most of the scrap. It probably won't be a big money maker unless there is somebody truly dedicated to recycling these things, and can accumulate enough of them in a short amount of time to turn them over for any large amount of profit. There is always money in quantity, hence that's half the battle.
Computer recycling is not only needed but on the rise, and really now is as good of a time as any to start figuring out new ways and methods to properly dispose of technologically advanced materials (especially if they are causing ecological damage to society by going to the landfills). There are a lot of other odds and ends to computers too. I have been in the scrap industry for a few years now and having had access to a thirty five thousand dollar hand held Niton x-ray machine
I guess curiosity got the best of me at times and helped me stumble across the percentages and values of certain objects. Know your material and don't get ripped off. Know how much weight you have before you cash in, and remember that some items are only worth going for if one were to plan on saving a considerably large amount. It may be worth the time to you or it may not. Who knows?...
Well I hope that what little knowledge I possess will benefit somebody else as it has myself. If you choose to recycle computers there are hundreds of ways and many possibilities - just find your niche and have fun.......
Bruce O [surname deleted for privacy by Editor]
- Willoughby, Ohio
A. When considering recycling in the computer arena, remember that there are other things of value besides the metal. Bruce above stated that printers are worthless. (They probably were in 2005 when he made this comment) Now, however, printers can be an easy money item. The cartridges can be removed and recycled for up to near 20$.
Some will pay for shipping and send preprinted labels when you sign up. Demand for old/broken printers appears to be pretty low so they may be had fairly cheaply.
Mark Parrish
- Kansas City, Missouri
Q. Hi
I am currently getting into the recycling business with a partner and I have two questions. I have been looking into the recycling of computer parts like described in the response and I am willing to keep for a while to get enough to make it worth my while. But when I do save up a load of computer chips where do I send them. Near me there is no computer chip, motherboard recycler around. And with other metals where can I get the current price per pound, because I get different answers from scrap yards. I would like to keep up on it.
Jamie L Casucci
- Cheektowaga, New York
Ed. note: People understandably would like this page to answer all of their questions. But apologies: we can't be a free eBay, waste exchange, or ad space provider. Sorry. We've tried it over the years, and it always leads to drowning under spam, plus shills posting with fictitious names, posing as glowingly satisfied users :-(
We do technical Q&A's here, but can't say where to buy or sell stuff -- that's for google. Apologies.
Platinum and disc drives
How do I separate Platinum plating on the hard disc platters and what is the procedure to purify or refine the platinum?
Muhammad Omer
jewellery maker - Karachi, Sind, Pakistan
Q. I was reading some of the letters of your avid site readers. I have a lot of junk computers in my shop and I need some suggestions or help on how to recover the platinum metal from the hard disk of the computers.What are the things I need or chemicals needed to extract the different metals found on the hard disk.and the procedures.thank you and God bless you all.
Giovanni B. Carantes
woodworks - Baguio City, Philippines
? I was unaware that there was any platinum on hard disk platters. Where can you point us that will tell us how thick and pure it is and what it is mixed with please?
A. I believe that the plated hard drive disks have a mixture of cobalt, chromium, and platinum. Platinum being about 5% to 12% of the plating. Not all the disks have the platinum plating on them either. Not real sure on the scrap value of this item yet, or how to refine it. With a guess from my research, about 15 tons of platinum are used in the electronics field, with the main source being the hard drive disks. There are plenty of hard drives out there, so I'm sure that at some point somebody will figure out how to refine the material and offer a monetary value for the item.
Bruce Opdahl
- Willoughby, Ohio
A. First you have to liberate your precious and tramp metals into solution, use either ion exchange or electrowinning for recovery. You'll need many permits and you can expect a visit from the HAZMAT fellows in their goon suits. You're far better sending your metals out to a licensed refinery, pre preparation is the key to saving money. Good luck with your endeavors and remember a Hazmat visit could be very expensive.
Gill Almgren
- Melita, MB, Canada
Q. HOW Platinum IS RECYCLED FROM hard disc platters and platinum condition in nitric acid.
Muhammad hammad
refining the gold - sargodha Punjab Pakistan
August 28, 2010
Q. Where is platinum located in the salvaged hard drive?
Jim delk
- muncie, Indiana
February 18, 2011
A. I work in hard drive production. I can tell you the manufactured disks have either a glass core or an aluminum magnesium core, and then a super thin-film coating of magnetic material, then diamond-like carbon, also thin-film. The platinum is sputtered on with other materials in a layer just 10s of angstroms thick, along with cobalt, chrome, etc. Total manufactured price is under $1 per disk, the amount of platinum involved is minuscule.
Sng Guil
Engineering - San Francisco, California
September 13, 2011
A. It's taken me just about forever, but I've finally found some way to answer the simple question "How much platinum is in these hard drive platters showing up on eBay for salvage?" "The Chemistry of Computing" over at extremetech.com (www.extremetech.com/computing/77316-the-chemistry-of-computing) has all the facts: surface layer of Co-Cr-Pt alloy is 40-50% platinum, and the layer is ~30nm thick. I don't have a hard drive platter in front of me, so let's just forget about the hole in the middle for a moment, so one platter from a 3.5" disk is 3.14*(3.5/2)^2=10.4 sq inches or 67.2 cm^2 ... times the 30nm thickness (3x10^-6 cm) is 2.0x10-4 cm^3, times the (optimistic) 50% Pd, times the density of Pt (21.45 g/cm^3) and I estimate one platter has at most 2.2 mg Pt. As of 08/29/2008, the platinum spot price was 1470.00 USD per troy ounce, or more usefully, 4.73 cents per milligram.
So, congratulations, you've just spent an hour of time and three cents of chemicals (just a guess, probably high) to reclaim 10 cents of platinum, probably still contaminated with cobalt and chromium depending on your recovery method. I hope you bought a whole bunch of platters cheap and rode a bike to pick them up because I doubt you'll be paying for gas let alone the shipping with the platinum. Or hope those early hard drives used a much thicker layer....
Kevin Hughes
Looking for work - Tarzana, California
July 19, 2012
thumbs up signThank you for stating the facts so that I don't have to waste my time finding out that I'm wasting my time.
Good Day!
Charles Lindsey Jr
- Deep Gap, North Carolina
Q. What Computer parts have Gold, Silver, Platinum in them? I know the boards do but what else, the wire? if so what ones? Some say batteries -- what batteries? Is there platinum in the disc drive? Where?
Thanks Larry
Larry Edgington
hobby - Guthrie Center, Iowa
Neodymium magnets
magnet_tiny_neodymium
A. Hi. I have one on my lap I got from the dump and have gotten a LOT out of it so far.
No one mentions the magnets. They are typically Neodymium magnets though some like for the hard drive motor itself tend to be ceramic.
In the hard drive the part that moves across the drive has a somewhat banana or curved shape to it.
Use care when removing! I recommend (goggles on eBay or Amazon [affil links] for sure) putting one end of its casing in a vice then using pliers or other means to bend the CASE the magnet is mounted to as if to peal it away from the magnet. Get that as far as you can then use a knife (so the edge can cut any glue) to complete the separation. Use caution. Neodymium magnets are very brittle and can send shards flying. There power also makes them likely to attract sharp metal objects so watch out for nearby items that are metallic.
Also the parts of the DVD and floppy and CD often contain Neodymium magnets. Use a screwdriver (metal) to find them next to the lenses. I then use a knife blade to pry them the mount away from them (not them from the mount - again they are brittle and can be dangerous of they shatter).
I then recycle these into wind generators.
Other parts I question (and fishing for answers here) like the contact wires inside the plastic cases that the gold plated contacts go into (not knowing if silver or aluminum) I hang onto.
Just because we may not know an easy way to extract the valuable materials now - doesn't mean we won't find an ecological and economical way to do so a few years from now.
So would anyone know regarding the capacitors if there is any metals or value to those? (I'm seriously considering using them for batteries) And THANKS for all the wonderful contributions here I really learned a lot!
And if anyone wants (or can) to email me if they allow that here I don't have much $ but could really deal with more of these Neodymium magnets since I don't just make my own wind generators I'm wanting to make enough of them to sell.
They use the larger and the small magnets.
Thanks again!
tree kneeland portrait
Tree Kneeland
- Anchor Point, Alaska
Ed. note: Hello, Tree. We're publicly discuss subjects like recycling of e-waste, but the internet is gigantic and when we tried to offer to print email addresses and be a free eBay we were quickly swamped. Apologies.
Q. I'm in the process of finding recyclers locally for things like plastic and fiberglass and in the future, glass, maybe. I'm currently crushing old glass and ceramic with a hydraulic jack and steel plates to fill a 115 year old well under my house (long story). I have a stockpile of computer parts with the room and available containers to separate and store these things. I manually remove any visible copper from the computers, power supplies and monitors; I use the cct lights from scanners for boredom projects like lighting shadow boxes and kitchen cabinets; the metal box with all the wires coming out of it has a brushless fan which I've found MANY uses for like force venting my crawl space, venting my grill (inside's a hotplate to heat pc boards for removing IC chips, the hundreds of gold plated leads, and almost everything on the board, and propane to melt the insulation from copper wire). My big question(s) are (mainly for Bruce) is there any documentation, maybe with a few pictures to help identify the valuable parts/metals from the scrap to keep from getting ripped off? I do some metal and iron work that requires an extreme amount of heat so would melting the copper (and maybe other metals) into chunks for easier bulk storage (as opposed to the barrel full of loose wire) be feasible? I am also a disabled insomniac with OCD so I have to constantly be doing tedious projects so I dismantle electronics. That is also the explanation for my run-on explanations and questions. I have found that with most hard drive platters, you can bend them to separate the outer coating from the platter. I know I have other questions but my thoughts are racing and I just can't seem to hold them down long enough to type them out. Thanks a lot for your help.
Steven
Steven Jenkins
- Boaz, Alabama
February 23, 2009
Q. Hi, I have pounds of older hard drive platters. I just sold 33 pounds of motherboards, memory, cpu's & pci cards ie: video-network & so on. One person I spoke with said that the platters are worth money. Just wondering what alloy is mixed in with the aluminum, they're just too strong to be just aluminum. Last is there a market for the motors/spindles that turn the platters & the magnets. I was told the magnets are worth selling, just need to know if that is true...... Thanks, Dan from Oakland County, MI.
P.S. I just sold this lot for $109.75 USD + shipping.
17 lbs. 7 oz motherboards
8 lbs. 6 oz PCI cards
2 lbs 7 oz memory
1 lb 3 oz ceramic processors
1 lb 1.5 oz intel 478 processors
0 lb 9.70 oz non ceramic processors
0 lb 14.7 oz sister boards
0 lb 12 oz slot A, slot 7 processors
Dan Jennings
computer repair / reseller - Waterford, Michigan, US
March 16, 2010
My name is Mike, and I'm new to this whole process I am in the game more or less because life has become somewhat boring and I have found new things seem to rehabilitate my drive in general.
Having said all that I would like to simply ask two questions.
1. Is there enough platinum or other exotic on hard drives to make them worth the time and energy it takes to accumulate them and perhaps how much per pound could they be worth?
2. I have accumulated about 8-10 pounds of very nicely plated Gold pins, etc...
And I am aware that this can vary widely but does anyone have an opinion on a lot that size what one can expect at a minimum if they are in fact as plated as I have described?
Again I would say 50% is completely plated and the remainder would be about 20-35% plated.
I will keep my correspondence shorter in the future.
Also there's some great people out there please keep up the good work helping others from what I have read in the future there are some great minds out there.
Thank you Mike........
Mike Healy
Student of life - Danvers, Massachusetts
Q. I have found that taking apart CRT's is somewhat lucrative also. In my city, you can go down any alley and find one or two laying out by the garbage. They contain copper wires, copper yokes, and a nice big circuit board. The only downside is disposing of the glass. I also have a question. Do older computer towers typically have more precious metals than newer ones? Thanks, great website!
John Davis
- cashton, Wisconsin
October 28, 2010
A. I'll give you guys a little insight since I actually work in the e-recycling industry. The name of the game here is VOLUME. In order to really net any money, you need to either deal in large volumes direct to a smelter like we do or at a step down from that, find a company like mine that has those relationships and can give you top dollar for proper disposition of the items (beware of all of the droves of Chinese companies with American names who just send your stuff out the back door in a container bound for Asia...they'll usually pay the most for computers since they have no dismantling costs).
CRT's and broken LCD's cost money to get rid of; no way around that...leaded glass in the CRT's and mercury in the LCD's which have to go to EPA certified facilities for proper handling once the units have been dismantled. There's money in the yokes & boards, but that's quickly eaten into by the cost to get rid of the glass and your labor. Printers are worthless other than the toner cartridges out of laser printers and the free paper that's usually left in the trays ;)
The high value items in the PC's are indeed the motherboards, the RAM and the processors and older is better = more precious metals. For example, a Pentium 4 is worth about $9-10/lb, Pentium I is worth about $110/lb. Motherboards/high grade boards will typically fetch us around $4.20/lb (we'll pay around $3.30/lb to get them...we *do* have operating costs that have to be covered with a large facility and $2 mil in shredders and optical sorting equipment). My last batch of mixed RAM netted just shy of $19/lb and is probably closer to $20-21/lb now. Mixed processor lot sent at the same time (heavy on Slot 1 processors which are about the cheapest) was about $29/lb. BUT, in order to get these returns you need volume (as well as storage space as most large smelters take a truckload at a time and you have to ship on THEIR schedule based upon how they've scheduled their processing) and you have to wait about 2 months to see your money. We'll typically pay $0.20/lb to get low grade board like what comes out of the CRT's and TV's, but you need to bring us at least a gaylord full to make it worth our time. IIRC the yokes are up around $1/lb. We have several local recyclers who bring their stuff to us because we pay more than anyone other than the Chinese exporters (and we match most of their pricing). If you're looking to get into this, your time is best spent accumulating, doing very basic dismantling and sorting and letting a company like ours do the 'heavy lifting'. I'll typically pay upwards of $0.30/lb for a PC, then we'll dismantle it separating the battery (goes to a battery recycler), processor, motherboard, memory, DVD drive (still has some resale value, CD's stay with the case & go through the shredders), heatsink & processor fan. Plastic is basically worthless and everything else is basically a game of pennies...you need volume to make money off of that stuff. Hope this was of some help.
Schuyler L [surname deleted for privacy by Editor]
- Mansfield, Ohio USA
December 28, 2010
Wire Stripper Machines
wire_stripper_machine
A. Your question is very complicated and simple at the same time. In the current market whole PC's are purchased as a commodity as are all the components (HDD, board, processors etc).
While opinions vary, most recyclers are doing things in an environmentally responsible manner. By the way, every pound of Cu, Al, Fe recovered via secondaries (like scrap wire or hard drives) is a pound we don't need to mine!
Scrapping of all sorts can be somewhat lucrative if your expectations are low (spare money as opposed to living wage). If you want to go full force it can be very lucrative but you need deep pockets (at today's prices anyway).
The main problem is that most individuals who are willing to give you a PC also need you to take an old CRT. (If they give you an LCD with an unbroken screen and case, take it! LOL).
Now you have a positive (PC) and a negative (CRT). The CRT is most likely going to cost you money to get rid of the right way. Some municipalities have free recycling programs for TV's and CRT's. If yours does best thing is to use it.
Some printers have reusable value, some cartridges do as well. Right now if I have large volume of printers I am lucky to get a few cents a lb. delivered to the recycler.
Stay away from your aluminum can recyclers with your scrap PC's. If they take it they will pay almost nothing. Instead you can collect a few hundred pounds of high grade stuff (such as old RAM, processors, PC mother and peripheral boards) and send off to a refiner.
A lot of people advocate refining at home. I am not one of them. The potential health hazards cannot possibly be worth it.
While you are waiting to get enough high grade to ship make sure you sell your "content" items. Power supplies, harness wire, things like that. What you can get depends a lot on how much you can collect before selling. Call around, shop a few prices before selling.
I am in this business but I won't discuss pricing because it changes regularly and it also varies with quantity. However, it can be worth it.
I hope my response to your question is helpful. Recycling is a lot of fun! Even if doing it on a personal level may not make you a fortune you learn a lot about things by looking at a waste stream.
Hope you enjoy and good luck.
Mike Ainpour
- Chicago Illinois
thumbs up signHoly Shnikes Batman! This has proven to be an excellent thread! I appreciate Finishing.com and people willing to share and enlighten us. I am relatively new to this but I have gleaned a great amount of information and have already began to reap the rewards. I wish there was more references to fair secondary smelters by city/state. So far it's hit and miss on where to go and how to handle volumes. These e-cyclers are willing to pick up truck load volumes so far, but the prices are so vastly different. One guy pays $2/lb to drop off where another pays $4/lb to pick up. I am separating every component until I know better. Hard drives, readers, ram chips, IC's, CPU's, gold fingers, etc. My local recyclers gladly take my aluminum, copper and sheet steel. Hopefully I can find someone to work out a nice package envelope so we can get our local government and surrounding municipalities on board to process e-waste.
Thanks for all who take time to share their experience and knowledge!
Jeremiah Pate
- Dothan, Alabama, USA
May 16, 2011
