Stainless finishing
What are some ways to grind and polish stainless steel and match a 4B finish? We have some areas where in line wheel tools will not reach.
Scott Smithelectrical enclosure mfgr. - Freeburg, Illinois, USA
Probably the most economical way to achieve any kind of surface finish is via a mass finishing system; however, matching an existing finish may require some work. Meaning, you need to select the proper shape media and composition. In most cases, ceramic and plastic media will give you you a slight galvanized pattern appearance. To achieve the 4B type finish, you may have to go to a secondary step process or a dry abrasive organic media.
AF Kenton
