Citric Passivation of 410/420 Stainless
Anyone know the proper way to citric passivate 410/420 CRES stainless? We are using a proprietary citric-acid based solution, but after a while see rust after doing a corrosion test. I'm sure it has to do with how our process is set up. If an alkaline is necessary, any suggestions for an environmentally friendly one?
medical device - Rancho Santa Margarita, California, United States
Ed:
We get excellent results with the correct product using citric acid on these grades. We have customers with these grades who require the use of these products because of 80% reduction in corrosion problems compared to nitric passivation. Best overall results according to some steel manufacturers is AAA method, Alkaline/Citric/Alkaline.
You need to be using the best formulation of citric on these grades and at the correct time, concentration and temperature. Ultrasonics can benefit also. There are a variety of proprietary methods to achieve the best results.
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
