Acid reaction with metals as identification
Q. I work in the aircraft industry and need to find out what metals will react with various acids. this is purely for identification purposes. I am trying to find what acids are used, when applied on metals, e.g., aluminium, magnesium, silver, copper, etc. will react by showing a colour identification similar to litmus paper.  an example of this is finding metal in a oil filter and trying to identify what metal it is to locate the component which is breaking up.
hope you can help...thanks
John Aide
student - Sydeny, NSW, Australia
"Rapid Spot Testing"
by Andrew Holmes
A. I'm not sure if I really understand, but you can get a copy of "Rapid Spot Testing of Metals, Alloys, and Coatings" from Metal Finishing Information Service.
Spot tests for plating type identification
Q. Hi, I'm restoring some 60's Triumph motorcycles which have different plating on the various parts. After 50+ years of corrosion I find it hard to determine what plating is on some of the parts, chrome, nickel, or cadmium.
Is there any way to determine what type of plating is present such as acid reaction, scratch resistance, something else?
eric thies
restorer - Grand Ledge, Michigan, USA
November 30, 2019
XRF Coating Thickness Analyzer
x_ray_thickness
A. Hi Eric, if you had access to sophisticated test equipment like beta-backscatter and x-ray fluorescence machines it might be relatively easy. I hate to bear bad tidings but I think you'll find efforts to track down what plating Triumph put on them more rewarding than trying spot tests. The problem with spot tests is that it almost always takes two, and often three or more tests to identify the plating; and when it's worn through, so the substrate participates in the reaction, it can be especially hard. It's probably possible, but probably too much effort to be realistic :-)
December 2019
thumbs up sign  Thanks. Looks like more research for me.
eric thies [returning]
December 4, 2019
