Thread 293/21
Chemical film and anodizing
Is it chemical film per MIL-A-8625 / MIL-PRF-8625 [⇦ this spec on DLA]c, class 3 also known clear anodize. thanks
MAH HOONGWAIengineer - BUKIT MERTAJAM, PENANG, MALAYSIA
publicly reply to MAH HOONGWAI
No, Mr. Hoongwai, chemical film and clear anodize are different processes. Chemical film is a conductive chromate conversion coating of aluminum. Anodizing is a non-conductive electrolytic process which creates an aluminum oxide coating on the parts.
publicly reply to Ted Mooney
If you want a clear anodize, the corresponding MIL spec for the clear anodize is MIL-A-8625F Type II Class 1.
Jim GorsichCompton, California, USA
publicly reply to Jim Gorsich
