Passivation procedure for Electroless Nickel
What is the best passivation procedure for Electroless Nickel ? Can ENi protect against corrosion from Liquid PVC? Thank you for your help.
Enrique Segovia
- Mexico
Dear Mr Enrique, You can try to passivate electroless nickel in potassium chromate 110-120 °F or sodium chromate in 110 °F directly after electroless nickel hold in the bath 1-2 minutes. Regards,
Anders Sundman
Anders Sundman
Consultant - Arvika,
Sweden
