Need supplier of Silver Secret
I would like to know where I can purchase a product called Silver Secret that helps restored worn sliver plate. Thanks to Sophia D of Virginia Beach VA who recommended this product.
John Pillinggeneral enquiry - Weybridge, Surrey, England
Ed. note: We have located a source for this (and many similar resilvering solutions), John. We've put the info into a single FAQ for sourcing resilvering solutions because it became impossible to keep the sourcing info current on this and dozens of other letters scattered across our 50,000-page site. We think you'll find the FAQ convenient and informative.
I am just now beginning to learn about and collect silver. Having just purchased a beautiful tea set where the handle has been soldered to the body of the tea pot, I am wondering if I must pay a small fortune to have it replated (there's only the one inch area at the end of the handle).........or can I use one of the solutions discussed here to cover the soldered area? Obviously the soldering is not brass or copper so I'm not sure which silver solution will bond to the soldered metal. Additionally, if I use one of the solutions and it doesn't work, can I take the tea pot to a professional and have it redone?
Carol Wellsaspiring hobbyist collecting silver - Southfield, Michigan
December 28, 2009
December 29, 2009
Hi, Carol. If you know this to be a repair, it probably is just soft tin-lead solder. If it could be the original connection method, it might be silver solder, which is actually high quality brazing with a silver-rich material.
I think an immersion plating process like "Silver Secret" may work on silver solder, but it will not work on soft solder. Even a silver plating shop may have some problems with satisfactorily plating soft solder as it is very difficult to get good adhesion to lead-rich materials.
I don't think a professional would have any issue with the silver you attempt to immersion plate onto the teapot; but as implied, they may well have a significant issue with soft soldered joints..
