316 stainless for lead-acid battery making
if 316/316L is not recommended for battery acid, what stainless is recommended for battery acid
⇦ this on
Amazon [affil links]
. It's being used as a battery liquid level electronic indicator.
- Grand Haven, Michigan
September 3, 2020
We have experienced this problem of corroded machine parts use in lead-acid battery making. The acid use is Sulfuric acid. We have used the Stainless steel 304 grade and we want it change to grade 316. Will this grade resist the acid? How can we test the difference between 304 and 316 grade?
Edgardo V. EleriaTool and Die Making - Quezon, City, Philippines
304 is magnetic, 316 non-magnetic(check it out with a magnet)
Tom SngConstruction - Singapore
Sorry, Tom, that's not accurate. Neither 304 nor 316 is magnetic. It's the 4xx series stainless steels that are magnetic.
316/316L is not recommended for battery acids. Better than 304/304L but not for your probable conditions - strict concentration and temperature control might allow it but not worth the effort. Try Alloy 20. There are other alternatives.
James DivineConsulting Chem/Corr Engineering - West Richland, Washington, USA
We have the same problem with stainless steel.
Please let me know if you are able to find the correct type of stainless steel.
May be we can exchange views on related issues?
I Look forward to hear from you.
Kind regards,
A P Batteries - Nairobi
