Anodizing/Finishing 380 Die cast Aluminum
Q. I am rather unfamiliar with the anodizing process and am seeking information. We have a part that is made of a 380 die cast aluminum and from what I have read, this is high in silicon which makes anodizing difficult or impossible.
We are just trying to give some reasonable corrosion resistance when subject to the elements, and the finish is of less importance. If possible, a dull black finish would be just fine.
Is there an option for anodizing this type of part or do I have to look at alternate finishing methods? If so, what is a typical specification, i.e., coating thickness & standard that I should have on the drawing?
engineer - St Paul, Minnesota, USA
A. 380 die castings are not difficult to anodize - we do it all of the time. The only thing difficult is to get a good looking finish. - Long Island City, New York 2004 A. Aluminum die castings can be anodized and hardcoated. It is much more difficult to do and the resultant coating is not as hard nor as corrosion resistant as comparable anodic coatings on wrought alloys. The appearance of anodize on diecastings is a dirty looking brownish gray. Chris Jurey, Past-President IHAALuke Engineering & Mfg. Co. Inc. ![]() Wadsworth, Ohio ![]() 2004 |
A. 380 diecastings can be anodized but the appearance quality and corrosion performance that you need may be hard to achieve. I have seen 380 aluminum that has been pretreated with a chromate free conversion coating, e-coated (black) and then scribed pass 2000 hours salt spray.
Jonathan Flicher- Chicago, Illinois
Q. What is the recommended pretreatment for anodizing 380 Al castings ?
Should alkaline or acid etch be excluded?
- West orange New Jersey, USA
March 14, 2016
