Removing nickel plating from aluminum
Recently, nickel was plated onto a circular surface made of aluminum by means of Selectron Process. However, the surface has became rough and flaky. I'm looking for a way to remove the nickel plating without removing the aluminum, because the diameter of the circular surface is very critical.
Derek Lim
Aerospace - Singapore
GM,
Nitric acid shall be used to deplate Nickel on Aluminium surface safely.
Shankara Narayanan N
- Bangalore, Karnataka, India
