Jewelry Plating line in Indonesia is not plating hard and bright
I was set up a plating line jewelry in Jakarta, Indonesia. So my problem is after using between two months. How do let the surface more hardness and bright.
Desmond Ten
plating shop - Jakarta, Indonesia
Desmond,
You need to provide more info on the bath. Secondly, why don't you call in your chemical supplier. There are many good people in plating supplies in Indonesia who can help you very happily.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
