Electroplating tantalum onto tungsten
I am involved in the design of some specialized physics research equipment and wondered if anyone could offer me some electroplating advice. I need to electroplate a tungsten component with tantalum in order to provide a protective coating for the tungsten. The component will be temperature cycled through around 100 °C (210 °F). Is this possible and what is the maximum plating thickness? Any advice would be appreciated.
Robert Scott
Research - Oxford, Oxon, England
I don't think it's practical since tungsten is a difficult to plate substrate and tantalum is not ionizable in aqueous solution. Plasma spray and vacuum PVD processes are probably possibilities. The ASM Metals Handbook Volume 5 Surface Engineering addresses many of these issues.
