Measuring thickness of individual layers of triplex nickel
Is measurement of different Nickel layers (Triple Nickel) by Ultrasonic method possible, or is any other NDT technique available?
Vijaya Kumar S
Plating Engineer - Bangalore, Karnataka, India
Mr S Vijaya Kumar
Coulometric Testing of Tri Nickel is an accepted practice . STEP test is also possible . Distinct readings of the three layers is entirely possible. The instrument you need is made in the USA and sold by a well known maker in Chicago. Look for makers of Coulometric Thickness test instruments with a STEP test function.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
