Parameters for BLACK CHROMIUM PLATING
Q. We are plating nickel on MS plat. We want disposition black chromium plating on a plate (dia. 350 mm ,10 mm thick). So please tell me process, chemical composition, additives, brighteners, temperature of bath, pH, and other parameters for BLACK CHROMIUM PLATING.
THANK YOU.
Bhavin Patelelectroplater - Surat, Gujarat, India
A. Please give us those same parameters for the successful nickel plating that you are doing, Bhavin. Then people will know, by example, what level of detail you are expecting. Good luck.
A. Contact your Plating Chemical Supplier.
Asif Nurie [deceased]
- New Delhi, India
