I NEED TO PLATE A VERY SOFT METAL ONTO A ROLLER
I need to be able to plate onto a roller made of steel or stainless steel a 1 micron of a very soft metal all around the roller. The softer the better! The plating has to be much softer than a nickel electroform. Your help will be very much appreciated.
DAN LIEBERMANelectroforming user - SAN DIEGO, California, USA
Copper, tin, cadmium, and lead are four plateable metals that come to mind quickly.
Try Indium, it is very soft and easily plateable.
Russell Richter- Danbury, Connecticut, USA
Have you considered a Ion Vapor Deposited Aluminum (IVD). This is not a plating process but will provide a uniform "soft" finish.
Terence Savas- Irvine, California
DEAR DAN,
COPPER IS WHAT YOUR LOOKING FOR. AFTER 28 YEARS OF PLATING THIS WOULD BE YOUR BEST BET.
THANKS.
LAWRENCE BROWNING- MAYSVILLE, GEORGIA
