Best bolt finish
I am trying to specify a new finish for bolts going on our new product line. I have already chosen the grade and size of the bolts, 3/8-16 x 3.5. I am not sure as to what the best method of having the bolts finished is. They will be subject to salt water/salt air, hot, humid climates and hydrogen sulfide gasses. What is my best bet for a durable, cost effective finish?
Chris Yard
mechanical engineer - Watertown, Connecticut, USA
Mr Yard.
You did not specify how long you expected the finish to last. We assume you have something like 5-7 years in mind....
In order of cost effectiveness here are suggestions
1) Make Stainless Steel bolts ..
2) Mild steel, with 8 Microns Zinc Nickel 12 percent alloy and Blue Chromate with topcoat.
3) Zinc Iron alloy plate 8 microns with a Black finish + topcoat over Mild steel Bolts for 3 years life expectation.
asif_nurie
Asif Nurie [deceased]
- New Delhi, India
Hi Chris,
Mr Nurie is being conservative in granting life expectancy of your fasteners albeit in a corrosive environment. Zinc Nickel and Zinc iron should get you three to five times the above, much more in normal conditions.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
