Aluminum hardness testing with Webster tester
Q. A new element in our Quality Assurance program is the inspection of our raw material. We own a hand held Webster tester for checking the hardness of our aluminum extrusion but we do not have a table of Webster hardness for the various alloys and temper we use. We are looking for a chart that describes what the Webster reading should be for the following:
6061 T6
6005 T5
6066 T5
6063 T6
6064 T4
Laurence M. Perks
RV/Cargo Door mfg. - Nappanee, Indiana
Aluminum alloy 1100 6063 / T4 6063 / T5 6063 / T6 6061 / T4 6061 / T5 6061 / T6
Chemical composition: Si 1.00 max 0.20-0.60 0.20-0.60 0.20-0.60 0.40-0.80 0.40-0.80 0.40-0.80
Chemical composition: Fe 1.00 max 0.35 max 0.35 max 0.35 max 0.70 max 0.70 max 0.70 max
Chemical composition: Cu 0.05-0.20 0.10 max 0.10 max 0.10 max 0.15-0.40 0.15-0.40 0.15-0.40
Chemical composition: Mn 0.05 max
0.1
0.1
0.1
0.15 max 0.15 max
0.15 max
Chemical composition: Mg
N/A
0.45-0.90
0.45-0.90
0.45-0.90
0.80-1.20
0.80-1.20
0.80-1.20
Chemical composition: Cr
N/A
0.10 max
0.10 max
0.10 max
0.04-0.35
0.04-0.35
0.04-0.35
Chemical composition: Zn
0.10 max
0.10 max
0.10 max
0.10 max
0.25 max
0.25 max
0.25 max
Chemical composition: Ti
N/A
0.10 max
0.10 max
0.10 max
0.15 max
0.15 max
0.15 max
Chemical composition: others (each)
0.05 max
0.05 max
0.05 max
0.05 max
0.05 max
0.05 max
0.05 max
Chemical composition: others (total)
0.15 max
0.15 max
0.15 max
0.15 max
0.15 max
0.15 max
0.15 max
Chemical composition: Al
99.00 min
remainder
remainder
remainder
remainder
remainder
remainder
Density (lb/cu in)
0.098
0.097
0.097
0.097
0.098
0.097
0.097
Specific Gravity
2.71
2.7
2.7
2.7
2.71
2.71
2.71
Melting Range (approx.)
643-657 C
616-654 C
616-654 C
616-654 C
580-650 C
580-650 C
580-650 C
Average coefficient of thermal expansion (2 C to 100 C)per C
23.6 x 1/10^6
23.4 x 1/10^6
23.4 x 1/10^6
23.4 x 1/10^6
23.6 x 1/10^6
23.6 x 1/10^6
23.6 x 1/10^6
Modulus of elasticity (M Pa)
68.9 x 10^3
68.9 x 10^3
68.9 x 10^3
68.9 x 10^3
68.9 x 10^3
68.9 x 10^3
68.9 x 10^3
Temper
H12
T4
T5
T6
T4
T5
T6
Hardness (Webster B)
3
4-7
8-10
11-13
6-11
12-14
14-15
Tensile strength (M Pa): Ultimate
97
131
151
206
179
240
260
Tensile strength (M Pa): Yield
76
68
110
171
110
206
240
Shear strength (M Pa): Ultimate
62
N/A
117
152
165
N/A
207
Elongation (% in 50 mm)
18
14
7
7
14
7
7
Jose angel Martinez auces
- Delrio Texas
March 9, 2010
Q. Is there any reliable means of testing hardness of 6063 & 6005 aluminium without using a laboratory test?
We receive COC's with every consignment of aluminium, but have recently experienced material failure and wish to do in-house, factory floor checks, is this possible?
Jack Visser
- Johannesburg South Africa
April 15, 2011
A. Hi Jack
I think you can use a Barcol compressor/Webster Hardness Meter to check the hardness. It can't 100% determine whether the material type, but you can have a good hint with the hardness though.
Steven Yeung
- Dongguan, China
June 18, 2013
Q. What is the Webster hardness ranges of aluminium alloy 6005 T6?
I am in the ladder manufacturing business and it easy to verify material by using a Webster hardness tester.
Tinyiko Baloyi
- Johannesburg, South Africa
July 22, 2020
