Removal of Blue Blush deposits
Q. Does anyone know about "BLUE BLUSH" a term used in the powerplant industry.
I am faced with removal of blue blush from gasket surfaces (steel) with a thin deposited layer of blue blush that is very hard to remove by hand with a carborumdum stone.
Any fast way to remove chemically? (Sandblasting, and grinding are NOT acceptable methods to maintain the flatness of the underling steel gasket seat.)
engineer - Blaine, Minnesota, USA
A. Gentleman,
Electrolytic cleaning of the parts in Alkaline cyanide solution will solve your problem.
- Bangalore, Karnataka, India
A. Use of an oxy-acetylene torch will usually pop blue blush right off. Follow that up using a cracking stone.
Stephen Wi- Underwood, North Dakota, USA
April 9, 2013
