Staining of Zinc-Cobalt parts while machining
While machining a Cast Iron part plated with Zinc-Cobalt 20 micron thick coating, we face problem of discoloration. The machining is done using coolant with Ph in the range of 8.5 to 9.5 Could somebody suggest a remedy for this problem.
Thanks & Regards,
Saurabh
machining - Bangalore, Karnataka, India
Dear Mr Saurabh,
This process cycle is not recommended. Cast iron will behave in this way. Are you sure that you can't machine the parts before plating? A lot of masking options exist in order to not damage yr machined surface during plating. Regards,
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
