Thread 281/36
Analysis of Tin Plating Bath Solution
Q. Dear Sirs,
I am trying to find methods of analysis of a Tin Plating bath solution which consists of: Na2SnO3·3H2O = 70 gr/l, NaOH = 11 gr/l, and CH3COONa = 22 gr/l. I have to determine the concentration of Tin Stannate (Na2SnO3·3H2O) (gr/l) and Free Sodium Hydroxide(NaOH)(gr/l) in the above solution. Please, suggest methods.
Thanking in advance,
Chemical Lab - Tanagra, Viotia, Greece
publicly reply to Fotini Kiriakou
A. Dear friend,
You have to take 5 ml of bath solution add to it 5 ml conc. HCl and 5 ml starch indicator and titrate it against 0.1N Iodine solution. Multiply B.R. by 1.187 you will get the GPL of Stannous.
- Pune, Maharashtra, India
publicly reply to Onkar Kulkarni
Q. Dear Onkar Kulkarni,
I use the method you suggest for the tin stannic salts but add a nickel catalyst to the tin and HCl and boil to a receiving vessel for 40 mins and titrate as your method. This is time consuming but does work; is your method comparable with mine? I will try your method out.
Many thanks,
- Wrexham
publicly reply to Ian Jones
Q. Dear friend
I would like to thank you for your response to the first part of my question, determination of Sodium Stannate. I would really appreciate if you or anybody else could give me a method for the second part of my question that is the determination of Free Sodium Hydroxide in the Tin Plating Solution Bath.
Thank you again,
A. Dear Fotini
mix 10 ml of vat sample with 50 ml Cl2Ba (10%) and a few drops of thymolphtalein indicator. Titrate with 1N hydrochloric acid to blue end point.
Titre x 4.00 =g/l free NaOH
PS: due to absorption of the indicator by precipitate, add few extra spot of indicator a half way point of titration.
- tehran iran
publicly reply to hadi khosravi
Dear Hadi, thanks a lot for your response to my question. It will help me very much.
Have a good day.
- Tanagra, Greece
Q. Dear sir,
What is meant by 10 Vat sample in the free alkali test you had mentioned. Please suggest; I am waiting for your response.
- Thane, Maharashtra, Indian
April 14, 2015
publicly reply to mahesh patil
A. Hi Manesh. Hadi surely means a 10 ml sample from the vat (tank or bath) of tin plating solution which you wish to analyze. Best of luck with it.
publicly reply to Ted Mooney
