Painting Galvanized Steel Posts
Primer for Galvanized Metal
primer_for_galv
Duplex Systems: Painting Over Hot-Dip Galvanized Steel
by American Galvanizers Association
duplex_systems
(Free!)
We are building a new farm fence with galvanized steel posts. Our contractor says we can't paint the posts white like the rest of the fence because the paint won't adhere and it won't look good. Is this correct? Is there a work-around alternative?
Kirk Brunson
Homeowner - Rowlett, Texas
A. Kirk,
He is possibly right. Look for a Zinc based primer to go on as the first layer. That will help the white you want , to adhere to the galvanizing. Let the primer dry. A second coat is optional. Follow with the paint.
The galvanizing must be new for good adhesion. or it needs light sanding to improve roughness and promote adhesion of the primer..
asif_nurie
Asif Nurie [deceased] [deceased]
- New Delhi, India
I've worked in a galvanizing plant in Peoria IL and they always told us to wipe Lemon Juice on the part we wanted to paint. It opens the pores in the galvanizing so paint will stick.
Steve Haahn
- Farmington, Illinois
